nycstev
Someone at the nats mentioned some one has a specialblend of meth?
I used quite bit on my RT to the Nats
:rock: :rock:
Stinker said:pm Bone he has a killer mix bro
souns like something you would usejoemags54 said:I use a 50/50 blend of distilled water and Geritol![]()
I hope that ain't what killed his engine...Stinker said:pm Bone he has a killer mix bro
SRT-MIKE said:You can use zero degree windshield washer fluid. Lately I'be been ordering "Boost Juice" from these guys:
http://www.snowperformance.net/product.php?pk=3
A little pricier, but it is formulated for boosted engines and hopefully there is better quality control over the contents.
Prof, I've been told by a reliable source that windshield wiper fluid rated for sub-zero temps has small quantities of ethylene glycol, which in the long term could burn a glazing over the cylinder walls and chambers.
Deibs said:Anyone just put in 100% methonal?
I thought that the water was actually a good thing for the cooling effect.Ram From Hell said:Is it worth the risk of a fire you cannot see in daylight?:dontknow:
tinygiants said:I thought that the water was actually a good thing for the cooling effect.
You almost don't wanna see what we do at work then... The oilfield in Alberta is one big unmoderated playground,, can't even count the number of guys i've seen filling methanol containers while smoking.... it's just silly, but good luck telling them different. Grade 10 education making 100K a year.. :dontknow:Ram From Hell said:Is it worth the risk of a fire you cannot see in daylight?:dontknow:
Nowwhat said:it is....turns out 50/50 results in the most effective cooling....
