I was having an erratic 1-2 shift, felt like tranny was slipping under heavy load in 1st and 2nd, and sometimes would miss (delay) a full throttle 1-2 and 2-3 shift.
I was fearing the worst and researching aftermarket transmission options, but given the state of the economy, figured I'd give it a go fixing it.
So, I did a complete fluid exchange with my new (to me) T-Tech machine, changed filters, front and rear band adjustment, replaced governer pressure solenoid and transducer (got them from electricaladvantage.net), and adjusted the TV cable.
Wow - back to it's old self again! Very happy that I didn't have to spend $6k to replace it... yet.
This is on my 2005 QC with 35k miles on it. 3rd transmission service with band adjustment (by dealers) on two prior ones - figured I'd do it this time since warranty is gone.
So, I'd say it's worth the effort to keep up with the band adjustments and solenoid replacements. I took the shotgun approach and did it all at once while the pan was off so I can't say which fixed it. That said, I'll replace both solenoid and transducer every time just in case. Cheap enough.
