Rice Eater
Well I went down to my local tire shop and bought two 17" rims off a stock RAM 1500 for $50 each. He mounted up my ol' MT ET streets on them. I went home...jacked her up and busted out the air wrench. Test fitted the rims on there, bolted them down and spun the wheel loooking close for any rubbing on the calipers since a few of you have said some gringing is necessarry with 17's. Well with these particular rims NO GRINDING IS NECESSARY! I put the other one an and headed to an empty parking lot to test them out. Its fun to have a set of tires you can smoke and not worry about burning off the tread!
After a good warm up the tires hooked very well on black top dumping the clutch at 3,000 RPMs....a little wheel spin but nothing like the stockers. So I know they hook up better....the question now is will I run out of gear...they are approximately 4'' shorter than the scorps. I will probably run either tomorrow night or Friday night and will post results. I hope that I don't run out of gear but am right near red line in 4th at the trap because then I will have addressed traction off the line and lower gears with only 2 $50 rims and some old drag slicks I had laying around! I have a hunch that I"ll be ok because I had these on my old Magnum and they were 2'' shorter than my stockers and I really didn't notice that much of a change in MPH and RPM's at the traps. Keep your fingers crossed 4me. Here is the link to some pics...couldn't upload them from photobucket for some reason??
http://s6.photobucket.com/albums/y226/Surfer27/SRT 10/
