2005ViperRam
Well-Known Member
- Joined
- Oct 13, 2012
- Messages
- 154
- Reaction score
- 275
Hey all,
I know there has to be other newbies like me out there so I will post this Trivia I just found out.
I am replacing my Upper Control Arms with Moog CK7424, sometimes called K7424, arms that include the dust boot. For some reason Moog doesn't put the dust boot on, so you have to go through that hassle yourself. It is a bitch!
The dust boot has a "Mount Inward" on the rubber, and I just didn't understand what was the reason. I search the internet, along with Moog technical information but no one ever says why. Being an engineer with OCD, I had to know why. Do you know?
The reason is they have a drip edge on the rubber that allows the excess grease from going onto your brakes. It drips inward, away from the brakes. I thought that was kind-of cool to know.
Anyways, I am posting Moogs instation procedure for the dust boots. After spending a couple hours doing it their way, I decided to figure something better. The thing I found is if you buy a 1 1/2 inch plastic PVC coupler, that works perfectly around the ring of the boot. Kind-of smouch it down most of the way, then on the last section that still is not setting flat, then use channel locks. It gets in there way easier.
Attached are a couple pictures.
