Yes she likes red ,,, the race Prius was red but the other Prius was the fastest color , BLACKVery nice rides!!! I think she did a great job on the decals
would love to see the race Prius! Hahah to cool
and it seems she enjoys Red
Uhhh huhhhhYes she likes red ,,, the race Prius was red but the other Prius was the fastest color , BLACK
Nice ,, definitely show truck .. paint must be candy apple red ,, my guess anyway .Heres a pic - see the incredible build thread for more ....
Yes ! Still going to test it on the engine and undercarriage of my Dakota first hahaha ! On the wheels it’s not a spray on and rinse thing though .. still had to wipe them off with a wet rag and then dry rag .. was easy to wipe off as wiping down your kitchen counter after doing the dishes and less elbow grease than cleaning a toilet hahahaWow!
Is that the SUPERCLEAN DEGREASER in action??
Wow! That stuff works great! Thanks for the demo! And I'm so glad the wheels weren't rusty!!Yes ! Still going to test it on the engine and undercarriage of my Dakota first hahaha ! On the wheels it’s not a spray on and rinse thing though .. still had to wipe them off with a wet rag and then dry rag .. was easy to wipe off as wiping down your kitchen counter after doing the dishes and less elbow grease than cleaning a toilet hahaha
Already test that and on soap scum on the bathtub tile wall … no it did not even with using a scrub sponge … the toilets have a slight hard water ring and didn’t do anything .. I’ve even tried that CLR stuff and it worthless ..Would it work on the toilet??
Mine have been cleaned and maintained from new … the damn water here stinks , I won’t drink it … it doesn’t take long before the hard water ring starts here .. a water softener would probably help a lot . I have scrubbed the ring and finally removed it ,, to much damn work ,,, there has to be a better way hahaha I’m hiring hahahaSome Toilets are beyond hope.
Everything is biodegradable hahahaThere is a diagram on the front of the container that shows fingers turned to bone.
I'm assuming the acid content is high enough to chew through just about anything, over time.
"A Cleaner for your toughest Toilet Challenge!!"
Good thing they put a Biodegradable Badge on the label too. It makes some think you are doing good things for the planet every time you pull the trigger.
It looks like the SUPERCLEAN stuff works though!
I'll be using that in the Spring (soon I hope).
Looks like it worked great!! I think I'll get a bottle of that for spring cleaning!Just did one of my beater dakota wheel ,, different kid of finish on the wheel .. it was my work truck for years and now the daily or should I say monthly driver …… before , after and a pic of the inner rim , one not clean and the other cleaned … can only use the 1 or 2 finger method .. but took about a minute … then dried wiped it to finish .. the inside f the rims have never been clean since new 2002
Drain the bowl and use a pumice stone and Polish with an electric bufferMine have been cleaned and maintained from new … the damn water here stinks , I won’t drink it … it doesn’t take long before the hard water ring starts here .. a water softener would probably help a lot . I have scrubbed the ring and finally removed it ,, to much damn work ,,, there has to be a better way hahaha I’m hiring hahaha
Like some humans! lolSome Toilets are beyond hope.
